Headlight and tail light not working
206,535 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the vehicle's headlight and the tail light are not functioning. I have checked the fuse , I couldn't see anything wrong with it. Please could you help me with the circuit diagram?
Mar 5, 2021 at 2:35 AM
  • 110,248 POSTS
The wiring schematics are broken into two sections, headlamps and exterior lighting. The rear tail lamp issue will be under exterior lighting. The headlamp will be under headlamp.
_______________
ore rea
Pics 1, 2, 3, and 4 are for the headlamp. I cut the pic in half to make it more readable. I did, however, overlap them so you can follow it.
Pics 5,6,7 and 8 are the exterior lighting schematics. Again, I cut them in half to make it make them more readable and I overlapped them as well.
______________
Here is a link you may find helpful as well:
_____________
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Mar 5, 2021 at 1:45 PM
BLESSING EWOBOR
  • 753 POSTS
Mar 7, 2021 at 3:50 AM
  • 110,248 POSTS
You are very welcome. Let me know if I can help or if you have other questions.
JOe
Mar 7, 2021 at 10:11 AM
BLESSING EWOBOR
  • 753 POSTS
Sir, is there any manual or sheet that list these meaning of the acronyms used in the circuit diagram? sometimes they are difficult to understand.
Mar 11, 2021 at 12:13 PM
BLESSING EWOBOR
  • 753 POSTS
Does the fog light comes on with the tail light or is there any circuit description for these?
Mar 11, 2021 at 12:16 PM
BLESSING EWOBOR
  • 753 POSTS
With the switch removed, what should someone find on the F FOG, HEAD, TAIL,A is it ground or power?
Mar 11, 2021 at 12:23 PM
  • 110,248 POSTS
I need to better understand. Where are you testing? Do you see something at the wiring schematics you are using? What colors are the wires? Most grounds will be black.
Mar 12, 2021 at 9:36 AM
