Head gasket torque setting
108,000 MILES
D3ADK1N6D0M
Replacing the head gasket I need torque specs for head bolts head rocker arms.
Jul 27, 2019 at 7:20 AM
Good afternoon,
Attached is the sequence for tightening the bolts.
Make sure you use only new bolts since they are torque to yield bolts.
Tighten the new cylinder head bolts to 60 Nm (44 lb ft) in the order shown. Use the J 36660-A torque angle meter in order to rotate the cylinder head bolts an additional 95 degrees.
The rockers are the same. New bolts only as they are torque to yields.
Jul 27, 2019 at 7:57 AM
