Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
SAAB
9-7X
Engine
Cylinder Head
Gasket
Replace/Remove
Head gasket torque head bolts
2006 SAAB 9-7X
180,000 MILES • 4.2L
GARYSGARAGE
MEMBER
Can you tell me the order and torque to be used when replacing the head gasket and tightening the new TTY bolts?
Jun 27, 2020 at 10:19 AM
Experienced Mechanic
I attached the specs for the head. Let us know if you have other questions. Thanks.
Images (Click to enlarge)
Jun 27, 2020 at 10:49 AM
GARYSGARAGE
MEMBER
Thank you so much. Same car listed above; do you know the bolt pattern and torque specs for the oil pump/timing chain cover?
Jun 30, 2020 at 3:37 AM
You are welcome. I attached the requested info. Thanks again for using 2CarPros.
Jun 30, 2020 at 11:34 AM
Here is a video to help you use a torque wrench correctly:
https://youtu.be/juOClONIWeY
Jun 30, 2020 at 11:43 AM
Add image or video
Ask a new question
