Head gasket replacement
160,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BRIEL15
When I purchased my car I knew it needed a head gasket replacement, but a mechanic started it but scammed me and took my passenger side head for the engine. I want to know should I buy a refurbished head for that side and have a mechanic install it and finish the job or would it be better to sell the car? Also if I replace the missing head, I know I'll have to get the other head cleaned. Correct?
Jun 29, 2019 at 5:58 AM
Hi Briel,
Sorry to hear that happened. Getting a replacement head is the route I would go if you want to keep the vehicle. However, if you don't then you may be able to sell it as is but you will not get as much for it.
If it were me, I would get it repaired and then decide what you want to do with it. As for removing and cleaning the other head, that is only necessary if there was an issue. Was the head gasket bad on that side as well? If not, I would not remove it. Plus, heads are not normally cleaned or rebuilt unless there is an issue.
Please let me know if you have other questions. Thanks
Jun 29, 2019 at 6:21 AM
BRIEL15
I do plan on keeping the car. I'm unsure if the other head is bad. I'm pretty sure it should be fine. People kept telling me that if I replace the head on one side then I should either get the other clean or replace it also because it would be a difference in pressure in the engine. Is that true?
Jun 29, 2019 at 6:31 AM
No. That's not true. You measure the compression on the other side and if it is okay then you leave it alone.
Here is how to perform a compression test:
Basically, removing a head is pretty extensive and you only do it when you need to. If there is no reason to remove it, leave it alone and do only the side that needs it.
Jun 29, 2019 at 7:36 AM
