After replacing the water pump, head gasket, and timing chain; the engine cranks but does not start?
114,500 MILES • 3.5L • 6 CYL • TURBO • 4WD • AUTOMATIC
2010-FORD-TAURUS-SHO
I got my head gasket, water pump and timing chain replaced, and my car will not start now. It will crank but won’t turn over. I tried starting fluid that did not help still cranked but did not start. I replaced the battery and while working on the car an trying to start it ruined the battery.
Jun 12, 2023 at 3:42 AM
  • 110,248 POSTS
Is it possible for you to record it cranking and upload it for me to hear? Also, if starting fluid made no change, check to make sure there is spark at the plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find. Also, if I can hear it cranking, I should be able to tell if there is a timing issue.
Jun 12, 2023 at 2:56 PM
