Head gasket
200,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
$TEVE0
If you don't have a blown head gasket and you put bars leaks in the radiator and run it through the engine will it mess your engine up?
May 27, 2020 at 4:07 AM
Good evening,
Bars leak does absolutely nothing for the blown head gasket. The issue is this sealer actually clogs up the radiator and heater core for circulation.
I would have the system acid flushed to get rid of all that stuff.
Did you have it confirmed about the head gasket?
May 27, 2020 at 7:57 AM
STEVE W.
  • 15,421 POSTS
In theory it shouldn't, however I have seen it plug radiators and heater cores so they no longer work properly.
May 27, 2020 at 8:04 AM
