HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Engine Cooling
Leak
Leaking antifreeze
CWESTWOOD79
MEMBER
1994 FORD EXPLORER
3.0L
6 CYL
4WD
AUTOMATIC
151,031 MILES
My truck is leaking antifreeze and was told it might be the head gasket. I cannot mess up another vehicle.
Friday, April 7th, 2017 AT 8:54 PM
HMAC300
MECHANIC
Pressure check coolant system for leaks and or use chemical additive available at auto parts. They may also have a pressure checker available.
SPONSORED LINKS
Saturday, April 8th, 2017 AT 7:48 AM
Please
login
or
register
to post a reply.
Related Leak Content
1994 Ford Explorer Coolant Leak
Engine Cooling Problem 1994 Ford Explorer 6 Cyl Automatic 145481 Miles Vehicle Has Developed A Substantial Coolant Leak At What...
Asked by
thompsonbe
1 ANSWER
1994
FORD EXPLORER
VIDEO
Cooling System Pressure Test For Leaks
Instructional repair video
GUIDE
Coolant Leak Symptoms
When your car begins to leak coolant the first indicator is the engine will start run hot and possibly overheat. This will be noticed by the driver by observing the...
1994 Ford Explorer Coolant Loss
Last Night I Went To The Grocery Store About 2 Miles From My Home. Stopped At The Gas Station On The Way Back. There, Coolant Was Pouring...
Asked by
liljerry67
1994
FORD EXPLORER
94 Ford Explorer Xl Cooling System
Odometer: 135, 00; Automatic; Radiator Replaced 1 Yr Ago Cooling System Water Is Boiling Hot, Can Hear Boiling Water, Then Backs Up Into...
Asked by
Roxy's ford
1 ANSWER
1994
FORD EXPLORER
1994 Ford Explorer Thermastat
My Suv Is Leaking Coolant Front The Bottom Of The Water Pump But The Engine Cools When I Keep Coolant In The Over Flow Meaning I Believe...
Asked by
hreggie39
1 ANSWER
1994
FORD EXPLORER
1999 Ford Explorer Coolant Leak
I Have A Small Coolant Leak On The Right Side Of My Engine. I Can See It When Looking Through The Wheel Well. It Looks Like A Round...
Asked by
afdan
1999
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Online car repair manuals
