Head gasket
2000 VOLKSWAGEN GOLF
170,000 MILES • 2.0L • 2WD • MANUAL
CHEJDUGAN
Hey, i bought this car two months ago (the elderly gentleman who i bought it from has not driven the car in a year). Had the oil, filters, coolant, break fluid all changed after the purchase. I am now noticing a lot of milky yellowish gunk around the oil cap and a sweet smell from the exhaust but the coolant level is not dropping so no coolant loss. Is this the early signs of head gasket failure?
Nov 23, 2017 at 7:56 PM
  • 110,241 POSTS
The creamy substance in the oil is an indication of coolant mixing with the engine oil, and yes, the sweet smell from the exhaust is an indication of coolant entering the combustion chamber. However, coolant usually creates a lot of white smoke when burned. So in short, it does sound like the gasket is already leaking.
Nov 24, 2017 at 12:38 PM
CHEJDUGAN
I only seem to have white smoke on morning, after the engine warms up there is no smoke. Another thing that I have noticed is that if I have the car sitting in neutral and give a few revs black powder comes out of the exhaust. The milky substance is only on the oil cap and not on the dipstick. How can coolant be mixing with the oil if the coolant reservoir levels are not dropping at all?
Nov 25, 2017 at 12:58 AM
  • 55,399 POSTS
This could be normal for a car that was not been run for a while. Have you run a few tanks of gas through it? Moisture on the cap is normal for an engine that has not been hot multiple times.
To be safe though we can test for a blown head gasket pretty easy. Here is a guide to help you.
Please let us know what you find.
Cheers, Ken
Nov 27, 2017 at 8:15 AM
CHEJDUGAN
I will be taking the car to my mechanic after Christmas so I will post the outcome then. When I drive the car for a long period and check the oil cap after the butter/mayo like substance is gone. One thing i forgot to mention before is when the engine is on and car is in neutral you can smell the sweet smell from the exhaust inside the car. I have also noticed on the dipstick above the oil level there is a slight amount of the whie/yellow creamy substance. The oil is still the same colour, not brown. Also the check engine light is not on. Thanks for the replies. I will reply after the new year. Happy Holidays
Dec 7, 2017 at 11:23 PM
  • 55,399 POSTS
Yep it sounds like you have a blown head gasket. Please let us know and the cost as well if we may ask.
Dec 8, 2017 at 9:23 AM
CHEJDUGAN
Yea I thought as much. I am hoping it won't be very costly. I didn't pay much for the car to begin but there was other things I wanted to do. Once I get it to the mechanic I will post a reply and let you guys know. Thanks for the replies and input.
Dec 10, 2017 at 4:15 AM
  • 55,399 POSTS
That would be great :)
Dec 16, 2017 at 5:02 AM
