Do you replace head bolts when you replace head gaskets
249,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
LEANNE SMITH
If so what do you use for lube?
Nov 17, 2019 at 2:06 AM
Good afternoon,
Yes, replace all the head bolts with new only.
No, there is not lube. That will effect the torques. They get installed and torqued dry.
TORQUE SPECIFICATIONS
CAUTION: Cylinder head bolts must be replaced with new bolts. They are tighten-to-yield designed and cannot be reused.
Tighten the LH cylinder head bolts in three stages in sequence shown:
Stage 1: 37-43 Nm (27-32 ft lbs.).
Stage 2: Rotate 85-95 degrees.
Stage 3: Rotate 85-95 degrees.
Tighten the RH cylinder head bolts three stages in sequence shown:
Nov 17, 2019 at 2:46 AM
