head bolt torque and sequence
130,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
MASIO520
Can you please tell me the head bolt torque spec and sequence for a 2011 Cadillac escalade premium ext 6.2L
Oct 29, 2018 at 12:37 PM
  • 110,248 POSTS
Here is the sequence for torque.
_______________________________________
8. Tighten the cylinder head bolts.
1. Tighten the M11 cylinder head bolts (1-10) a first pass in sequence to 30 Nm (22 lb ft).
2. Tighten the M11 cylinder head bolts (1-10) a second pass in sequence to 90 degrees using J 45059 .
3. Tighten the M11 cylinder head bolts (1-10) a final pass to 70 degrees using J 45059 .
4. Tighten the M8 cylinder head bolts (11-15) to 30 Nm (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
I hope this helps. Let me know if you have other questions.
Oct 29, 2018 at 2:00 PM
MASIO520
Thank you so much!
Oct 29, 2018 at 2:38 PM
  • 110,248 POSTS
Happy to help. Let me know if you need anything else.
Oct 30, 2018 at 10:08 AM
