Head bolt tighten specs needed?
245,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
JERRY CULWELL
What does the head bolts torq down to and sequence.
Aug 17, 2025 at 1:06 AM
  • 55,676 POSTS
Hello Jerry,
Here is the cylinder head bolt tightening torque specs and the tightening sequence as well.
1st step torque: 20 Nm (2.0 kgf-cm, 14 ft. lbs.)
2nd step torque: 49 Nm (5.0 kgf-cm, 36 ft. lbs.)
3rd step torque: 67 Nm (6.8 kgf-cm, 49 ft. lbs.)
Check out the images (below). Let us know if you need anything else.
Aug 17, 2025 at 5:35 AM
