Hazard switch blowing fuse
189,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JAMES JORDAN
  • 5 POSTS
The left and right signal lights does not work. The lights does not come on. When I turn on the hazard switch the fuse blows. The signal lights does not work even when there is a good fuse installed. I am not sure where to go. Changed the fuse and the hazard switch.
Oct 21, 2017 at 2:47 AM
  • 55,851 POSTS
It sounds like you have a bulb socket that has melted. Please remove both front and both rear bulbs for inspection. Check down inside the socket.
Here is a guide that can help you see what Im talking about.
https://www.2carpros.com/articles/brake-lights-not-working
Its for brake lights but follows the same principal.
Please run some tests and get back to us so we can keep helping you.
Cheers, Ken
Oct 23, 2017 at 5:41 AM
JAMES JORDAN
  • 5 POSTS
That resolution solved the issue with the hazard lights blowing fuses. The speedometer and tachometer stay at zero. They do not function at all no indication of RPMs or current speed whatsoever. The odometer also does not function and the Systems Monitor says "TIRE PRESS" even though its not low. The turn signals and cruise control also do not work. The lights on the radio does not come on. It seems to be an issue with the instrument cluster. Help
Nov 4, 2017 at 9:31 AM
  • 55,851 POSTS
Can you show us what went wrong with the lights? Give us a picture or video?
Nov 5, 2017 at 5:17 AM
JAMES JORDAN
  • 5 POSTS
I will send a screen shot of the Cluster soon. Just trying out how to paste it here.
Nov 17, 2017 at 11:54 AM
  • 55,851 POSTS
Do you see the "ADD IMAGE OR VIDEO LINK" ? that should work let me know if you have trouble.
Nov 18, 2017 at 6:37 AM
JAMES JORDAN
  • 5 POSTS
Here is a copy of the cluster screen shot.
Nov 20, 2017 at 1:33 PM
  • 55,851 POSTS
I would disconnect the battery for 5 minutes and then reconnect it to see if the cluster resets
Nov 22, 2017 at 2:43 AM
