Hazard lights coming on when I use signal
156 MILES • V6 • 2WD • MANUAL
FELICIANO81
Why does my hazard lights turn on when I put my turn signal on? Does it
Have a flash relay if so where is it?
Dec 7, 2018 at 8:57 AM
  • 110,248 POSTS
There is a relay in the under hood power distribution box. See picture 1.
Also, check ground 7. It is under the dash, left side. I attached two pics which are schematics. I am questioning that ground because it is common to both components.
Let me know if that helps.
Dec 8, 2018 at 12:32 PM
