Hazard lights
133,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
STEVENSUNDERMAN76502
So all my lights work, turn signals, headlights. My hazards is the problem it works but I only have my right front flashing other flashers do not flash, but turn signals work. Fuse in dashboard panel is good. What could it be?
Oct 28, 2018 at 9:14 AM
BMDOUBLE
  • 1,139 POSTS
Possible weak ground g100 top left of radiator support. All of the bulbs except for the right front get their ground from this location, so if it is weak it will work for normal turn signal purposes, but when in hazard mode the extra load with not allow any of the bulbs other than the right front from working. The right front bulb's ground is g101, right front fender apron area.
Oct 30, 2018 at 5:34 AM
