Hazard/exterior lighting diagram needed
100,000 MILES
SEBASTIANFROMNJ
  • 40 POSTS
Okay, so customer's car, hazard switch literally burned up. Replaced switch and pigtail. Now hazards blink intermittently when car is key off/engine off. Apparently Mitchell doesn’t supply wiring diagram for this model. It’s listed above with a 2.0.
Anywhere to look?
BCM has a b2159
ECM does have check engine codes but there is no light in cluster.
Does anyone have the correct wiring diagram?
Nov 15, 2020 at 8:40 AM
So that B code would not turn the check engine light on. That is considered a non powertrain code so they are there as informational purposes when the customer makes a complaint. This may be related so I attached the testing along with the diagram you requested.
Let's run through this testing and see what turns up.
Nov 15, 2020 at 8:50 AM
SEBASTIANFROMNJ
  • 40 POSTS
Sorry, should have mentioned the PCM code is p1409. I believe unrelated to this problem I just thought the light not illuminating in dash was related to BCM. my apologies.
Nov 15, 2020 at 9:07 AM
SEBASTIANFROMNJ
  • 40 POSTS
And this hazard flasher diagram is wrong colors.
This is what Mitchell Prodemand shows me as well it’s very confusing.
There are 3 orange/black wire and 2 orange wire ones thicker, running right off of pigtail. I rewired in new pigtail. Flasher switch was used but I don’t think that’s the problem. When car is running the hazards don’t flash and everything works appropriately.
Nov 15, 2020 at 9:15 AM
SEBASTIANFROMNJ
  • 40 POSTS
There are also other wires. But those wires I listed are different. Is it possible they’re not included in the diagram?
Nov 15, 2020 at 9:17 AM
Can you try and post those diagrams that you are looking at? A lot of times the wiring color may be different but it may be due to the options on your vehicle. I understand it is a 2.0L Focus but is it a wagon, ZX3, ZTS?
If you tell me if the VIN is a 3 or P I should be able to figure out what happened. Thanks
Nov 16, 2020 at 11:08 AM
