Rattling noise by transmission fluid pan, and overheating
2006 DODGE DURANGO
234,300 MILES • 3.7L • V6 • 2WD • AUTOMATIC
KESHIA30
When I try starting, it runs rough then smooths out like its catching to start smooth, rattling noise by transmission fluid pan, and overheating after inserting antifreeze with coolant leak. I don't know what to do. I have no check engine lights on the dashboard. Also, after turning it off sound like it whining noise that whines down some slowly. Please help!
Mar 17, 2019 at 9:49 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a bunch of different things. Let's pick a corner and start to figure this guy out. Have you fixed the coolant leak yet? I have included a few links down below in case you haven't.
https://www.2carpros.com/articles/engine-coolant-59420607
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/car-is-leaking-coolant
Please go through these guides if needed and get back to us with what you find out or to let me know that the coolant is fixed and we can go from there. With a little patients and perserverence we will get this figured out.
Thanks,
Alex
2CarPros
Mar 17, 2019 at 10:30 PM
