Fluctuating RPM's after I cleaned the throttle body
290,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
DAMO35
I cleaned the throttle body on my vehicle and now when at idle it fluctuates high low revs.
Apr 10, 2020 at 4:05 PM
Good morning,
What did you use to clean the throttle body? If you use the wrong cleaner and it takes the coating off the plate, you could damage the throttle body itself.
Apr 10, 2020 at 9:39 PM
DAMO35
I used throttle body cleaner.
Apr 11, 2020 at 12:43 AM
Some of them are too harsh on the coating.
It sounds like you need to replace the throttle body.
Apr 11, 2020 at 1:01 AM
DAMO35
Can I just get a second hand one and put straight in??
Apr 11, 2020 at 2:04 AM
Yes, you can. Make sure it is clean and not damaged.
Apr 11, 2020 at 2:34 AM
