Turn over but want start need to know what the problem1995 dodge Dakota truck
Jan 9, 2016 at 12:59 AM
CARADIODOC
✓Experienced Mechanic
What have you checked so far, and what were the results? Which engine do you have?
Jan 9, 2016 at 1:01 AM
BROWNSTACY
MEMBER
Where do the pickup coil plug-in to on wiring harness on a 1995 dodge Dakota pickup is it top of motor on the driver's side or down on transmission
Feb 12, 2016 at 2:04 AM
BROWNSTACY
MEMBER
5.2 engine
Feb 12, 2016 at 2:05 AM
CARADIODOC
Are you referring to the crankshaft position sensor? That is behind the right cylinder head in the transmission's bell housing. The camshaft position sensor is in the distributor.
Feb 12, 2016 at 2:39 AM
BROWNSTACY
MEMBER
Where is the pickup coil plug-in where does it plug into on the wiring harness
Feb 12, 2016 at 2:45 AM
CARADIODOC
What are you referring to??? I told you where the two sensors are. Those are often called "pickup coils".
