Transmission not shifting properly
220,000 MILES • V6 • 2WD • AUTOMATIC
ANTHONYPATTON85
hello, I'm having issues with my transmission. it doesn't go into reverse and when I try to go into drive you have to take off slow and it doesn't wasn't to shift into gears and the RPMs run to high when it happens.
I just changed the transmission filter it's a little better but still no reverse and it still has issues wanting to shift and RPMs are still running high.
Apr 10, 2021 at 10:24 PM
This sounds like a fluid level issue or overall fluid issue. so when you changed the filter what did the fluid look like? Was it red or dark and smell bad?
What I would suggest is flushing the unit completely and then retest. However, I had a 1998 Dodge that had this same transmission in it and it would act like this as well. I found that when I put a couple extra quarts of fluid in the transmission it stopped doing it.
If the fluid looks good now, just add a quart and see if it gets better. Don't worry about if it is a little overfull. Clearly we don't want to put 5 extra quarts in it but 1-2 will be just fine.
What was happening with mine is it would suck air and it would eventually bang into gears.
Let's start with this and go from there.
Apr 12, 2021 at 8:23 AM
