Have no spark
300 MILES • 2.6L • 4 CYL • 2WD • AUTOMATIC
JOHNNATHAN HAMMOND
I have power to coil but no spark. I have changed the coil, condenser, ignition module.
Apr 20, 2018 at 6:14 PM
HARRY P
  • 2,292 POSTS
I suggest taking a look at the Crankshaft Position Sensor. Is the service engine light on? If so, you should get the codes pulled and see what it says.
Apr 20, 2018 at 8:25 PM
JOHNNATHAN HAMMOND
No lights. on the motor where is the crank sensor?
Apr 20, 2018 at 9:05 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
There is a crank angle sensor inside the distributor.
That would usually set a code 41 though if it were bad.
Here is a test,
CODE 41 - CRANK ANGLE SENSOR SIGNAL > DIAGNOSTIC AID
Disconnect crank angle sensor harnesses at crank angle sensor connector.
Disconnect all connectors at ECM.
Turn ignition "on". Measure resistance between terminals 34 and white, 35 and green and black and ground. Resistance should be zero.
Measure voltage between green/black and ground. Voltage should be 10-14 volts.
When circuit is found to be in normal condition, replace distributor assembly.
Apr 20, 2018 at 11:20 PM
