I just put a timing beltang. It was a good stripper there so it was pulled have everything lined up has fire cranks but wont startwhat am I to do
Oct 14, 2014 at 7:30 AM
✓Experienced Mechanic
If the original timing belt broke, that is a problem. This is an interference engine. If the old belt broke, I need you to check engine compression. Most likely you have some bent valves.
Check that and let me know what you find. Also, let me know if the engine sounds odd when trying to start. If everything is good, will the engine start with starting fluid?
Oct 14, 2014 at 9:33 AM
RANDYSMITH761
MEMBER
okay will dothe engine will not start with starting fluidbut it seems to crank and sound okay
Oct 14, 2014 at 9:40 AM
Check the compression and let me know.
Oct 14, 2014 at 9:56 AM
RANDYSMITH761
MEMBER
okay I'll get back with you on the compression thank you
