coolant leak
85,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
COSTANZO
Put car on lift removed the shroud. Looks like the coolant leak is coming from gasket area on the drivers side on the bottom of engine.
Apr 19, 2017 at 7:14 PM
HMAC300
  • 48,601 POSTS
this may be a head gasket leak. use a pressure checker and pressurize the coolant system to verify there is a chemical you can also add to verify as well either is okay. auto parts rent a pressure checker.
Apr 19, 2017 at 11:01 PM
