HAVC blower motor not working
2006 BUICK LA CROSSE
285,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHEFLOUIS
Blower motor not working. Correct power to resistor, new resistor, fan, control module.
plug in blower nothing.
Oct 19, 2020 at 9:28 AM
Good evening,
I attached a wiring diagram of the system for you.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Can you check and see if you have power to the purple wire at the blower with the blower commanded on?
Also, check the red wire to the blower control as well to be sure the fuse I circled is sending power to the module.
Oct 19, 2020 at 10:02 AM
