Hatch glass will not latch/close
163,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CASMIHOK
  • 211 POSTS
All of a sudden the glass of my trunk isn't closing, can anybody help me?
I just got a new battery and haven't connected it because I'm in the process of transmission work so I can't drive it right now anyway. Could my battery have something to do with why it isn't latching? I'm hoping it's something simple. :(
Jan 23, 2020 at 6:59 AM
STEVE W.
  • 15,418 POSTS
If it goes gown but stays about an inch ope instead of latching it looks like the latch pawl that hold the glass has flipped closed. You can take a screwdriver, put it into the spot where the striker on the glass goes, hit the hatch release and see if it flips open. Mine did this a couple times until I sprayed it with some lubricant. The latch itself doesn't pop open, that is the function of the lever with the black rubber. The latch itself just rotates to open or close.
Jan 24, 2020 at 3:38 AM
CASMIHOK
  • 211 POSTS
Fixed it. was just because battery was disconnected and it wasn't communicating.
Jan 24, 2020 at 6:57 AM
CASMIHOK
  • 211 POSTS
Thank you Steve.
STEVE W.
  • 15,418 POSTS
No problem. Never had a battery swap cause that on mine. Had the latch trip and it wouldn't shut though.
But it works now so good.
Jan 24, 2020 at 11:54 AM
CASMIHOK
  • 211 POSTS
Yes sir, thank you.
Jan 24, 2020 at 12:01 PM
STEVE W.
  • 15,418 POSTS
You are welcome, drop by anytime we will be here.
Jan 24, 2020 at 12:11 PM
