Cranks does not start
2005 VOLKSWAGEN CADDY
23,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
TOMMY JOHNSON
Engine spins but does not start. Brings fuel to the injectors, but does not seem to have any electrical signal. All fuses are okay, the electric pump works in the tank.
Nov 9, 2018 at 5:32 PM
  • 55,412 POSTS
This sounds like the crankshaft angle sensor is not working. Can you check for spark at the plugs? This guide should help.
Cheers, Ken
Nov 12, 2018 at 3:06 AM
