Go to turn key over car powers up but no crank.
Also have to use two hands to shift out of park into gear. I am two hundred and ten pounds and avidly pick up heavy things.
1: Cut and installed 2.2k ohm resistor in between a small yellow and black wire to bypass pass-lock on ignition module.
2: Did check shifter by taking off cable connections at both ends (in car and at transmission?. Cable and shifter are good. However, link at top of transmission where the cable attaches to seems really hard to move. Guessing something internally is the issue.
Thanks
Thanks
Apr 15, 2017 at 9:57 PM
