Has no power and uses alot of fuel
1981 DATSUN 710
2.2L • 4 CYL • 4WD • MANUAL
NICKN91
I have rebuilt the carburetor and changed fuel filter and air filter all plugs and wires are less than a year old. I am at a loss I don't know where to look next I know it is just a four cylinder but it should have more power than what it does. I don't know the mileage because the odometer was broke when I bought it.
Feb 8, 2015 at 2:20 AM
CARADIODOC
  • 34,381 POSTS
The best suspect would be a jumped timing chain, especially if the engine is also hard to start. The only model I found that is close is a 720. That one with a gas engine uses guide shoes and a spring-loaded tensioning device, so there's all kinds of things that can allow the chain to become loose. Even if it didn't jump a tooth, a loose chain will cause late valve timing. That will cause real good low-end torque to tear away from a stop sign, but reduced high-end torque that will make it hard to pull out and pass people when necessary. A good clue, if you haven't adjusted ignition timing, is it will be considerably retarded from specs. If you did adjust it and had to go quite a ways with the distributor to advance it back to specs, also suspect a stretched or loose timing chain.
Feb 8, 2015 at 8:09 AM
