Harsh shifts, code p0961
175,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MIKE MCGILTON
I have the SUV listed above with a 4l60e. I'm having a harsh reverse to drive and 1-2 shifts. Has a code p0961. Changed pressure control solenoid and didn't help. Is there anything I can test further relating to this code?
Jan 26, 2022 at 8:33 AM
  • 110,248 POSTS
As far as this code being set, it could simply be related to a low voltage issue. Is the voltage supply (battery/alternator) in good condition and working properly? Here is a link that explains how to test an alternator. Do this just so we can confirm this isn't an issue.
Next, when you replaced the solenoid, did you inspect the wiring and connectors for evidence of damage, corrosion, or even a pin pushed or bent preventing good contact?
I attached an explanation and the diagnostics below related to the code. Take a look through them and let me know if it is something you are comfortable performing. Also, you will need a scan tool that can communicate with the modules involved.
Jan 26, 2022 at 10:11 AM
MIKE MCGILTON
Hey Joe, I ended up putting new tcm in and it solved the issues. Thank you!
Feb 4, 2022 at 6:03 AM
  • 110,248 POSTS
Mike,
Thanks for letting me know. I appreciate it. Also, it will likely help others.
Please feel free to come back anytime in the future. You are always welcome here.
Take good care of yourself,
Feb 4, 2022 at 10:51 AM
