ABS wire harness harness information
180,695 MILES • 3.4L • 6 CYL • 4WD • AUTOMATIC
ADOLFOV.
A couple of months ago i bought this vehicle not knowing that the ABS sensor wire harness was cut. after replacing both front wheel hub i don't know how or where that wire goes to to replace it.
Feb 10, 2019 at 9:02 AM
  • 55,746 POSTS
Here is the ABS wiring diagrams you need (below) with a guide to help you test the connections:
Oct 14, 2020 at 4:42 AM
