Serpentine belt smoking
108,000 MILES • 6.8L • V10 • 2WD • AUTOMATIC
TXSOLDIER86
This morning I turned my truck on to warm it up. Had it running for fifteen minutes then I went to shut it off then went back to turn it on and it wouldn't turn over. It felt like the alternator was bad so I went to test the alternator and it was good. Then I checked the battery and it was bad so I got a new one. I installed it and tried to turn the truck on and It barely turned over and when it did it started squealing really loud and smoking and smelled like rubber. I noticed that the harmonic balancer was really hot. I'm not a mechanic but I think that's the problem. I need some advice.
Jan 26, 2019 at 12:26 PM
BMDOUBLE
  • 1,139 POSTS
Try to crank it with the belt off. I’ve had A/C compressors lock up and cause the exact same symptom that you have described.
Jan 26, 2019 at 1:06 PM
TXSOLDIER86
How will I know if it's locked up?
Jan 26, 2019 at 1:18 PM
BMDOUBLE
  • 1,139 POSTS
You should be able to turn the front end of the A/C pulley by hand with the belt off.
Jan 26, 2019 at 1:50 PM
TXSOLDIER86
I couldnt take it off but it turns by hand
Jan 27, 2019 at 1:43 AM
  • 55,694 POSTS
Did you get the belt off to check all accessories could turn be hand? here is a guide to help you remove the belt:
https://www.2carpros.com/articles/replace-serpentine-belt
Jan 29, 2019 at 4:56 AM
