Harmonic balancer removal
220,000 MILES
JMZZZR235
I'm removing a harmonic balancer on the car listed above base model .Do I have to lower the sub frame to get it off or is there a trick?
Nov 23, 2020 at 4:07 PM
Good morning,
I attached the procedure and some pictures for the replacement for you.
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
You will need a puller. You can get one at a parts store.
Crankshaft Balancer Replacement
Tools Required
J 37096 Flywheel Holder
J 38197-A Crankshaft Balancer Remover
J 45059 Electronic Torque Angle Meter
Removal Procedure
1. Disconnect the negative battery cable.
2. Remove the drive belt.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the right front tire and wheel.
5. Remove the right engine splash shield retainers and the engine splash shield.
6. Remove the torque converter covers.
7. Use the J 37096 to secure the flywheel in order to prevent the crankshaft from rotating.
8. Remove the crankshaft balancer bolt and discard the balancer bolt.
9. Install the J 38197-A.
Important: Do not separate the crankshaft pulley from the crankshaft balancer. Service the crankshaft pulley and the crankshaft balancer as an assembly.
10. Remove the crankshaft balancer.
11. Remove the J 38197-A.
Nov 23, 2020 at 8:49 PM
JMZZZR235
My main question is, do you have to drop the sub frame to remove pulley?
Nov 24, 2020 at 12:24 AM
Hello again.
You do not have to drop the subframe.
You access it through the right front tire wheel well.
Nov 24, 2020 at 2:51 AM (Merged)
