new starter wont turn engine over. i can rotate it with beaker bar on crank pulley but it gets to a point and just about stops
Apr 11, 2016 at 1:18 PM
CJ MEDEVAC
✓ASE Certified Mechanic
REMOVE THE STARTER
WILL IT ROTATE WITH THE BAR? (ELIMINATING THE STARTER AS THE PROBLEM)
IF NOT
IF A CYLINDER HAS WATER (COOLANT) IN IT (HEAD GASKET ISSUE), IT WILL HYDRO-LOCK, AS YOU CANNOT COMPRESS WATER!
REMOVE THE SPARK PLUGS TO SEE IF IT PUSHES WATER OUT OF A CYLINDER
DOES IT TURN OVER AT LEAST 2 FULL ROTATIONS NOW?
THE MEDIC
Apr 11, 2016 at 2:33 PM
CJ MEDEVAC
MIGHT CHECK YOUR OIL FOR WATER BEFORE YOU START SNATCHING SPARK PLUGS!
THE MEDIC
Apr 11, 2016 at 2:35 PM
