hard to start in the morning, and lacks power
245,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
TRISHA2
  • 7 POSTS
my Saturn only starts went I push down on the gas panels if I don't it just shuts off, then the engine would shake even the car. when I drive it, it takes off down hill and when I come to a complete stop the car takes off really slow the rpm would go to 4000 and I release the gas panels it shifts and going up hills it loses poweruuntil I turn the car completely off and turn it back on it has a oil more power. I changed most of the sensors got the cat replace six months ago map sensor, o2 sensors, etc
Jan 9, 2014 at 1:22 PM
SATURNTECH9
  • 30,869 POSTS
Doesnt shift till you let off the gas most of the time thats a plugged cat I know you replaced it 6 months ago but sounds like one.Which one did you replace the one under the car or the one innthe exhaust manifold?Also are you sure you have a SL1 model can you post a pic of the car?
Jan 10, 2014 at 12:15 AM
TRISHA2
  • 7 POSTS
it's the one cat I replace in the middle of the car not the one close to the engine.
Jan 10, 2014 at 12:46 AM
TRISHA2
  • 7 POSTS
I tried posting a picture it won't work yes I have an sl 1 sohv
Jan 10, 2014 at 1:01 AM
TRISHA2
  • 7 POSTS
my car doesn't overhear just lacks power
Jan 10, 2014 at 1:54 AM
SATURNTECH9
  • 30,869 POSTS
Have you replaced the coolant temp sensor and inspected the connector for corrosion?Also the cat in the exhaust manifolds can clogg up or break loose.
Jan 10, 2014 at 3:59 AM
TRISHA2
  • 7 POSTS
ok I'll check it out I change the coolant sensor but don't know the manifold can clogg up. th first time it happen I was at a stop light and my car made a clogging sound thats when it lacked power. and started shaking it was running really good
Jan 10, 2014 at 5:58 AM
SATURNTECH9
  • 30,869 POSTS
Have a back pressure test done on the exhaust when it doesnt have power.
Jan 10, 2014 at 6:40 AM
