hard to start
12,000 MILES • 3.4L • 6 CYL • 2WD
BEVERLY MAYNARD
  • 31 POSTS
hard to start.
Jun 7, 2017 at 9:18 AM
  • 55,770 POSTS
Yes this is a common problem with cars, here is a guide that will help you get started.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Please let us know what you find.
Cheers, Ken
Mar 12, 2021 at 1:38 AM
BEVERLY MAYNARD
  • 31 POSTS
this car always hit on about 3 turns had had it check at auto zone it say oxy.sensor changed it but always started on 3 or 4 turns it just stop starting
  • 55,770 POSTS
A couple of things come to mind that I need you to check which can cause the o2 sensor codes as well. The first is a vacuum leak, here is a guide to check for that.
and a weak fuel pump.
Here is a guide for that as well
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
