Hard time starting
2003 BUICK REGAL
173,121 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DENISE LYNN WILSON
Car started fine 3 days ago and then the next morning was hard to start it took like 15 second and I thought it was going to die but then the car started . What can cause this problem.? Battery is new.
Dec 18, 2019 at 3:39 AM
Good evening,
I would start by checking the fuel pressure. You may have a bad fuel pump.
A common issue for the check valve to bleed off all the pressure back to the tank.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Dec 18, 2019 at 8:10 AM
