Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Impala
Steering
Symptoms
Hard
Hard steering
2006 CHEVROLET IMPALA
120,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
TERESA LUNSFORD
MEMBER
1 POST
I have replaced the rack and pinion and power steering pump and car is hard to steer sometimes and it jerks back and forth what. could it be?
Apr 21, 2019 at 8:41 PM
Experienced Mechanic
Good morning,
Did you use a new rack or a used one?
The moving back and forth is an indication of a bad rack.
Also, check the shaft from the steering column to the rack. There are two U joints in the shaft and if they are tight then it could cause the issue.
Images (Click to enlarge)
Apr 21, 2019 at 9:54 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
