Hard starts when engine is hot?
145,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
LADUKEJUSTIN
I purchased the car listed above a couple weeks ago and noticed that when the car is hot, i'm having a lot of hard starts. i have had the battery tested, changed spark plugs, changed oil, tested fuel injectors and the problem is still there.
Apr 12, 2021 at 9:15 AM
4DRTOM
  • 467 POSTS
If its only happening once its warmed up one thing could be the temperature sensor or another sensor the computer needs info from that is only failing after its hot. This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
ad
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Also, lets run the codes to see what come up.
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Tom
Apr 13, 2021 at 9:58 PM
