Car tries to start, but stumbles and shuts off
200,000 MILES • V8 • 2WD • AUTOMATIC
TOTALMC
  • 117 POSTS
Just replaced distributor , coil , cap and rotor , plugs and wires. The car was starting and running great (actually started it over a dozen times) then after sitting for a few days; it tries to start but stumbles and shuts off.
It was having this problem before I replaced the items as stated previously , and after checking the cap and wires found them corroded (enough that it was lucky to be running on 4 out of 8 cylinders) , so an ignition tune-up was due , and after resetting the timing it fired right up and ran great , but it seems only for that day.
Any help would be greatly appreciated.
Jul 8, 2020 at 6:36 AM
  • 110,248 POSTS
Have you checked to make sure the choke isn't stuck closed? Is it possible for you to record what it is doing and then upload it for me to hear?
Jul 8, 2020 at 12:01 PM
TOTALMC
  • 117 POSTS
Manual choke wired open (live in Vegas, so choke is rarely needed).
Jul 8, 2020 at 1:03 PM
  • 110,248 POSTS
There could be a few things. Have you checked to make sure there aren't any larger vacuum leaks? Also, have you confirmed that the fuel pump is providing enough fuel?
I realize this is a 68, but has anything been updated as far as ignition? I'm just wondering what we are working with, HEI or points and condenser.
Jul 8, 2020 at 2:46 PM
TOTALMC
  • 117 POSTS
This is the only upgrade to the ignition system, and a Holley 4-barrel. And like I said , it was running great over the weekend - started it over a dozen times and then a few days later , it's like I never replaced anything. I replaced a few vacuum lines also.
Jul 8, 2020 at 2:57 PM
  • 110,248 POSTS
Okay, is it possible for you to record what it is doing with your phone so I can hear it?
Jul 8, 2020 at 3:00 PM
TOTALMC
  • 117 POSTS
Car is at a different location at this time. but basically has a little trouble starting , and stumbles like it's missing on a few cylinders , and quits.
Jul 8, 2020 at 3:04 PM
  • 110,248 POSTS
The only thing I can think then is either a large vacuum leak or the carburetor is dumping fuel. Is there any black smoke from the exhaust or anything you can think of? The carburetor looks new, so I'm questioning why would it be fuel related.
Does it always start right back up and then repeat the issue?
Jul 8, 2020 at 3:11 PM
  • 110,248 POSTS
Also, I believe that distributor has a built in ignition control module, is that correct?
Jul 8, 2020 at 3:14 PM
TOTALMC
  • 117 POSTS
It didn't smell excessively rich , no smoke and sometimes a backfire out the carburetor when you try to restart it.
Jul 8, 2020 at 3:15 PM
TOTALMC
  • 117 POSTS
Yes , and the control module checked out fine.
Jul 8, 2020 at 3:16 PM
TOTALMC
  • 117 POSTS
And I don't think lack of fuel is an issue. It ran pretty strong throughout the RPM range as I raced it around the block several times on Saturday.
Jul 8, 2020 at 3:26 PM
TOTALMC
  • 117 POSTS
Only thing left I can think of is maybe the rings are so worn that the plugs are oil fouled already. Guess I'll have to pull them all back out , check them and do a compression test while I'm at it.
Jul 9, 2020 at 1:41 PM
  • 110,248 POSTS
It seems odd that it ran good for you on Saturday. I wouldn't think low compression would be an issue if it ran good then. However, anything is possible. Is there any blue smoke when you first start it?
Let me know what you find with the compression test. Here is a link explaining how it's done. I don't know if you need it, but thought I would add it just in case.
I will watch for your reply.
Jul 9, 2020 at 3:01 PM
TOTALMC
  • 117 POSTS
So re-checked everything today , reset timing even checked for timing chain play (pretty sure it was less than 10 degrees) and car still wouldn't run right. Then I replaced a connection on a wire leading to the coil , and it fired right up and ran better than it has for years after some fine tuning on the Holly. So after about a 10 minute drive, pull into the garage , start it a few more times to double-check - and then after 15 minutes it barely starts and runs like crap ( like a weak ignition I'm thinking ) ... The distributors been checked (MSD pro billet) coil , cap and rotor , plugs and wires all new. so what would cause this (what seems like an intermittent failure)?
If the timing chain was loose , it wouldn't have run great minutes previous , right?
Could it be a wiring issue that I'm going to have to dig deeper to find ??
I've included it video of it running , but the sound quality is not too good,but if you listen to the whole thing you can kind of hear I would seems to be missing a few cylinders , and dying whenever you give it some gas.
Thanks for any light anyone can shed.
Jul 12, 2020 at 10:29 AM
  • 110,248 POSTS
What is the clicking I am hearing? Also, what wire was replaced? Have you checked the coil itself? And yes, I agree the chain wouldn't be good one minute and then bad the next.
Jul 12, 2020 at 2:10 PM
TOTALMC
  • 117 POSTS
It was one of the wires going to the coil (not the ones going to the distributor) .. not sure which one it was , did not want to dig through the harness to find out where it went (even though I believe that maybe my next option because that wire could be bad). As for the clicking , when I listen to the audio on the video , it did not sound like that live .. more like it's missing on all cylinders , or maybe getting barely enough spark to fire.
Jul 12, 2020 at 2:43 PM
TOTALMC
  • 117 POSTS
The coil is supposedly new, plus wouldn't it just crap out , not work and then not work , just to work and not work again ??
Jul 12, 2020 at 2:46 PM
  • 110,248 POSTS
A coil can do this if it is going bad. Even though it's new, I have seen them bad. However, since the wire you replaced made a difference, I think you are on the right track. Can you take a pic of the wire so I can see which it is? There should be a + and a - for the coil.
Jul 13, 2020 at 11:43 AM
TOTALMC
  • 117 POSTS
My eyes were too bad to read which side was which , and didn't feel like climbing in there (or removing it) to read which was which. But I'll probably be testing (and maybe replacing) the new coils resistance along with new wiring to the coil.
Jul 13, 2020 at 11:58 AM
  • 110,248 POSTS
That sounds like a good idea. Let me know the results.
Jul 13, 2020 at 12:52 PM
TOTALMC
  • 117 POSTS
Will do. Thanks.
Jul 13, 2020 at 1:06 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just to add my 2 cents there is something you need to know about Holley carburetors. Any time you have a backfire through the carburetor it blows the power valve and needs to be replaced.Even if you replace the valve and have another backfire it has to be replaced again.This is most likely the reason you car is running poorly.There is a conversion kit that is offered to prevent power valve damage in the event of a backfire.A hole is drilled in the primary metering block and a check ball and spring is installed.Hope this helps and thanks again for using 2CarPros.
Jul 14, 2020 at 11:22 PM
TOTALMC
  • 117 POSTS
But the problem has been intermittent , car has run great in between. It wouldn't have ran great if it had a blown power valve , right ??
Jul 15, 2020 at 2:23 AM
  • 110,248 POSTS
I would think if the power valve was bad, it would not change. In other words, it wouldn't be good one time and not the next. However, he is correct about the backfire causing damage to it.
Have you had any progress with it?
Jul 16, 2020 at 7:43 AM
TOTALMC
  • 117 POSTS
It backfired a bunch of times before I got the distributor right , but then ran great afterwards. have not had a chance to test the coil or check the wiring yet.
Jul 16, 2020 at 8:42 AM
  • 110,248 POSTS
Not a problem. Let me know what you find when you get to it.
Jul 16, 2020 at 10:09 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, the performance would be affected by the power valve after a backfire.After getting things sorted out I would definitely change the power valve to improve performance from the carburetor.Keep us updated.Hope this helps and thanks again for using 2CarPros.
Danny-
Jul 18, 2020 at 12:30 AM
