Hard starting in cold weather
105,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JOE BANGNOSKI
I would not consider myself a technician, but have done most work on cars myself including putting an engine in my old Cadillac in my garage. My car listed above starts hard when below about thirty degrees out. Will have to crank it quite a few times and when it finally does start will run rich for a little less than ten seconds. Googled it and switched out the MAF and coolant temperature sensor with no results. Wondering where to look next. Thank you.
Feb 3, 2018 at 2:00 AM
  • 55,766 POSTS
It sounds like you have a weak fuel pump which is not pressurizing the system quick enough.
Here is a guide to help you run a test to confirm the issue:
and this gudie can help as well.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Cheers, Ken
Feb 4, 2018 at 4:37 AM
