Hard Starting and loss of power
1987 JAGUAR VANDEN PLAS
131,000 MILES • 6 CYL • RWD • AUTOMATIC
ZOMAN
Due to sitting for years and extensive water contamination. I've drained and changed almost every thing fuel related; tanks, filters, injectors, regulators, relays and ECU. Currently, my car has hard starting and has a loss of power when it hits 2000 rpms or so. I thought maybe it was the CAT(s), but they seem clear. It will idle ok, but when I attempt to accelerate. It boggs down with no power then will lunge forward, then bogg down again. Thank you.
Sep 16, 2014 at 4:48 AM
HMAC300
  • 48,601 POSTS
can for codes and check feuel pressure with a gauge 35.5-37 psi also could be the electronic unit for the fuel injection or a basic engine problem.
Sep 16, 2014 at 9:14 AM
