Hard starting after sitting, code P0420
214,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
BMIT
It starts fine in the morning and after a few minutes of sitting, but after a few hours (3-4), it cranks but doesn't want to engage. When it finally does, it splutters as if you flooded a carburetor on an older car, and there's a strong fuel smell. It's becoming a frequent problem. Code scanner lists P0420, but the catalytic converter is only a couple years old, as is the bank 1 O2 sensor. Also, I think this is just a symptom and not the cause? I have read about pressure regulator, pump, leaky injectors, etc., but none of the symptoms seem to quite fit what people describe.
Apr 8, 2022 at 3:16 AM
  • 110,248 POSTS
The idea that you smell fuel and have a converter code somewhat indicates one or more of the injectors is leaking fuel and then raw fuel is getting to the converter. That will damage it causing a P0420.
What I suggest is to inspect the fuel pressure. Once pressure is reached, turn off the key and see if the pressure drops off quickly.
Here is a link that explains how to check fuel pressure:
Let me know what you find or if you have other questions. Additionally, let me know if there are additional codes other than the P0420.
Apr 8, 2022 at 12:20 PM
BMIT
Thanks Joe, will do. I'll have to see about getting a gauge this weekend, and I'll get back to you.
Apr 8, 2022 at 11:30 PM
  • 110,248 POSTS
You are very welcome. Let me know what you find or if I can help in any way.
Apr 9, 2022 at 1:27 PM
