Hard starting
2003 TOYOTA CELICA
165,000 MILES • 2.1L • 4 CYL • 2WD • AUTOMATIC
RICHARD JOHNSON2
I have replaced injectors, coils, fuel pump spark plugs, etc.
Jun 28, 2020 at 7:31 AM
So we need to find out which system is causing the not starting. An engine needs three things to start, fuel, spark, and compression. So this is just a matter of finding out which one is causing this issue. That is done by eliminating each one, one at a time.
Start with fuel. To eliminate this, take starter fluid and spray it in the intake and see if the engine starts. If not, remove a spark plug and hold it against the block and see if there is ignition. Lastly we need to check compression.
Here is a guide on hard starting:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Here is a guide on how to do a compression test:
Let us know what you find. Thanks
Jun 28, 2020 at 12:44 PM
