Hard starting
255,239 MILES • 4 CYL • 2WD • AUTOMATIC
RASAQ218
I have the car listed above in my workshop and having hard starting when it's cold or early in the morning. I have tried replacing the engine coolant temperature and crankshaft sensor. I help need on this, thanks..
Jan 8, 2020 at 4:41 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
Does it have any stored trouble codes?
Here is a link to our tutorial on checking for codes:
Have you checked the condition of the fuel filter and checked the fuel pressure at start up? Fuel pressure issues would be my first suspect providing there aren't any codes. If you can let us know what you find on these points that would help us greatly in guiding you to the issue and thank you for using 2CarPros!
Jan 8, 2020 at 8:35 PM
RASAQ218
I checked the fuel pressure it's okay and no code stored. car runs fine after hard starting and start immediately when it's hot. I replaced ECM, spark plugs, camshaft sensor , crankshaft sensor and there's still no luck. what else did you suspect the problem should be?
Jan 9, 2020 at 2:15 AM
  • 55,644 POSTS
I could be the air intake boot is torn this guide can help you:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jan 11, 2020 at 7:13 AM
