Hard starting
200,000 MILES • 2.2L • 4 CYL • MANUAL
MIKE QUINTON
  • 5 POSTS
My car is hard to start. Seems like the fuel is leaking back to the tank. I have replaced the pump filter and pressure regulator. When it is hot out I have to turn the pump on three times then try and start it.
Jun 29, 2018 at 12:51 AM
  • 55,766 POSTS
Yes, this sounds like a weak fuel pump, but to be sure here is a guide to help you test the pressure:
With vacuum hose disconnected 265 - 314 kPa (38 - 46 psi)
With vacuum hose connected 206 - 255 kPa (30 - 37 psi)
Here is a guide to help you see what you are in for when changing the pump out. With diagrams below on how it will be for your car:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Please run down these guides and diagrams and report back.
Cheers, Ken
Jun 30, 2018 at 5:27 AM
MIKE QUINTON
  • 5 POSTS
Thank you. I just changed the fuel pump with one that is specified for that motor. Once it starts it runs great and does not sputter or anything at an idle.
Jun 30, 2018 at 10:41 AM
  • 55,766 POSTS
Nice, so that took care of the problem?
Jul 2, 2018 at 4:44 AM
MIKE QUINTON
  • 5 POSTS
No, it is still leaking back. I have to turn the key on and off three times to pressure the system. Once it starts it runs great. Even at an idle.
Jul 2, 2018 at 9:37 PM
MIKE QUINTON
  • 5 POSTS
The new pump that I installed earlier is what the manufacturer recommends for pressure and flow. It has got a lot of miles and I did not want to cause more problems by adding more pressure.
Jul 2, 2018 at 9:39 PM
  • 55,766 POSTS
It sounds like the fuel pressure regulator is stuck. I would try removing it to see if it holds pressure. Here is a diagrams so you can see what I am talking about:
Cheers, Ken
Jul 3, 2018 at 6:07 AM
MIKE QUINTON
  • 5 POSTS
Okay, I will try that. Thank you
Jul 3, 2018 at 1:47 PM
  • 55,766 POSTS
Happy 4th! Please let us know.
Jul 4, 2018 at 8:23 AM
