Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Mustang
Engine
Symptoms
Hard to Start
Hard starting
2001 FORD MUSTANG
38,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MR. BICEPS
MEMBER
1 POST
Engine cranks but will not start unless starting fluid is sprayed into the throttle valve.
Dec 12, 2018 at 4:13 AM
Experienced Mechanic
Good afternoon,
Does it stay running after you prime it or does it stall out?
This is usually the result of a failing fuel pump. I would start by checking the fuel pressure to be sure it is working.
If there is no pressure or low pressure, it will not start without priming.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Dec 12, 2018 at 5:08 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
