hard starting
50,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
BRANSKY04
will not start in cold weather,new battery.when it does start it runs like new.
Feb 12, 2016 at 11:21 AM
CATAFINA
  • 167 POSTS
Try checking the fuel pressure if its within specs-start here and then let me know
Feb 12, 2016 at 11:37 AM
BRANSKY04
does fuel pressure change once engine is running?
Feb 12, 2016 at 11:26 PM
CATAFINA
  • 167 POSTS
No-it should remain constant when engine fires-up; if it does and not within specs you have a problem
Feb 13, 2016 at 2:52 PM
BRANSKY04
i"m trying to make sure that i understand all of this completely,what your saying is that when the engine is running as i stated earlier and it runs like new and that is no exaggeration it runs amazingly,that the fuel pressure could not change from the cranking period to the running period.
Feb 13, 2016 at 10:42 PM
CATAFINA
  • 167 POSTS
Once you turn the key On-the pressure is there whether it starts or run
Feb 14, 2016 at 5:59 AM
BRANSKY04
yes fuel pressure is good.
Feb 15, 2016 at 1:13 AM
  • 55,694 POSTS
Here is a good guide on hard starting, please let us know what you find
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Feb 15, 2016 at 1:23 AM
