Hard starting
99,000 MILES • 6.0L • 6 CYL • 4WD • AUTOMATIC
BRAD WEST
Sometimes starts fine, sometimes cranks slowly or not at all. New battery, starter, starter relay, positive cables to starter.
Jul 22, 2018 at 11:59 AM
Good morning.
Do you have a voltmeter to check the battery voltage while cranking when you have the issue?
What about the ground cable? Did you check that as well?
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Jul 22, 2018 at 8:13 PM
