Hard start warm
120,000 MILES • 3.7L • 6 CYL • 4WD
CHRIS BURGE
  • 21 POSTS
I think I checked everything and replaced many parts. I still can not find out why its a hard start . New regulator, cleaned throttle body, good fuel pressure. Do you know if there is a solution?
Thanks
Mar 5, 2017 at 8:57 AM
CARADIODOC
  • 34,415 POSTS
What is the symptom? Have you checked for spark? Are you referring to the voltage regulator or the fuel pressure regulator? Have you read the diagnostic fault codes?
Mar 5, 2017 at 9:16 AM
CHRIS BURGE
  • 21 POSTS
P0304. Starts hard warm. New fuel regulator, plugs, wires, coil. Good compression. This is a tough one.
Mar 6, 2017 at 12:54 PM
CARADIODOC
  • 34,415 POSTS
I'm going to assume for now you have an unusually-long crank time. If that is correct, there's two things to consider. First, observe the fuel pressure when the problem occurs. If it has bled down over many hours, suspect a leaking fuel injector. The fuel pump will run for one second when the ignition switch is turned on, but that is usually not enough to get the pressure up high enough for the engine to run.
The second thing is to check for a failing crankshaft position sensor or camshaft position sensor. In the '90s, the engine would not start or run if either one failed. Around the early 2000s, the engine would continue to run if one sensor failed, but once stopped, it would not restart. I've been told by the mid 2000s, the engine will start and run with one failed sensor, in a back-up strategy, but it will take more revolutions than normal for the Engine Computer to determine which piston is coming up on top dead center. It has to figure that out before it will know which ignition coil to fire.
If you're lucky, there will be a diagnostic fault code to tell you if a sensor signal is missing. If there is no fault code set, you need to use a scanner to view live data. The two sensors will be listed as "No" or "Present" during cranking.
Mar 7, 2017 at 1:39 AM
CHRIS BURGE
  • 21 POSTS
Ok thanks, I will check with the scan tool. The fuel pressure was good, but I'll try the pressure drop test.
Mar 7, 2017 at 11:16 AM
CARADIODOC
  • 34,415 POSTS
Be careful with the fuel pressure test. The fuel pump is going to run for one second when the ignition switch is turned on. That can develop enough fuel pressure to seem to be okay. Instead, put the gauge on it, then let it sit. Read it later after the engine has been off for a while, before you turn on the ignition switch.
Mar 9, 2017 at 4:28 AM
