Hard start
427,800 MILES • 1.8L • 4 CYL • 2WD • MANUAL
KEVMUYA
I am experiencing hard start challenges with my vehicle listed above 504 saloon car. I have changed the spark plugs and fuel pump, which the mechanics felt were faulty, but still it doesn't work.
Kindly assist.
Jul 20, 2020 at 10:24 PM
  • 110,251 POSTS
This vehicle isn't offered in the US, so I have little to no technical info on it. However, I'll try to help.
First, is that the correct mileage you listed? If it is, has anyone checked engine compression?
Also, try this for me:
1) Turn the key from off to the run position (engine off) and count to 5.
2) Turn the key off.
3) Perform step 1 and 2 three times and on the forth time, see if it starts easily.
Jul 21, 2020 at 6:45 AM
KEVMUYA
Yes, the mileage is correct. secondly i tried the following steps, but still experiencing the same problem.
Jul 21, 2020 at 9:07 PM
  • 110,251 POSTS
The next thing I would suspect (based on mileage) is low compression. Has that been checked yet?
Jul 22, 2020 at 9:31 AM
KEVMUYA
Will check compression, maybe what would cause low compression?
Jul 22, 2020 at 3:02 PM
  • 110,251 POSTS
I'm basing that idea on the number of miles on the vehicle. Piston rings will wear over the miles. If the compression starts getting lower, it can cause a hard start.
Here is a link that explains more about causes:
https://www.2carpros.com/articles/the-reasons-for-low-compression
Let me know what you find.
Jul 22, 2020 at 10:46 PM
