Hard start
2006 OPEL
78,000 MILES
SIPHO SB
Corsa 1.7dti hard to start especially when the engine has been running for sometime. The car doesnt have power. I have just serviced the car, checked fuel pump is okey.
Apr 28, 2013 at 4:23 AM
SEANGRANT00
  • EXPERT
  • 334 POSTS
First thing I would do is get the computer (OB2) scanned. This will make it easier to help in the diagnosis. Most auto part stores will do this for free. When you get the codes, write them down and let me know what they are. There are many problems that could create this symptom and without speculating for hours let's try this out first and I'll be happy to help you out in finding the problem.
Thanks, look forward to your reply
Sean
Jun 27, 2013 at 1:52 PM
LUCKY NKOSI
I have big problem! my corsa 1.7 dti iz hard to start but is sparking right n timing is ok and putting petrol orght still is hard to start please help ineed this car please help
Nov 8, 2017 at 6:07 AM
  • 55,746 POSTS
It sounds like you may have a vacuum leak or an engine coolant temperature sensor that is out. I would test for the vacuum leak first and then go for the sensor here are three guides to help you find out whats going on.
and
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Cheers, Ken
Nov 11, 2017 at 2:54 AM
